Author Topic: 87 Burb with a saggy rear.  (Read 13715 times)
Offline Kazz
« on: February 23, 2003, 01:15:00 am »
What is the best/most popular way to bring the rear of the vehicle back up where it should be? It's got the normal back end is lower then the front thing going on.
Thanks,
Kazz
Offline Kevin108
Re: 87 Burb with a saggy rear.
« Reply #1 on: February 23, 2003, 11:54:00 pm »
There's no way to fix it, I'll get that junk out of your yard for $50.
:rollin
Is it lifted or stock?  A lot of guys add 2" add-a-leaves but I like the ride of stock springs so I'd say if it's stock just add 2" lift blocks or 2" over the amount of lift in front, within reason.
87 Silverado 4x4 Longbed Pickup
My Mods | Truck Pics | Kevin108@PavementSucks.com
Maker of 43 point turns!
Offline Kazz
« Reply #2 on: February 25, 2003, 12:38:00 am »
Thanks for the response Kevin but I think I'll keep it. My wife's rear sags too but she's worth more them $50.
It's all stock. I saw those 2" lift blocks in a JC Whitney catalog but I thought maybe there was a better way. Since they did come from the factory reletively level would just replacing with new springs bring it back up?
Thanks again,
Kazz
Offline Kevin108
« Reply #3 on: February 25, 2003, 11:18:00 pm »
If she saw you said she had a saggy rear, you'd need more than $50 to get out of the dog house with her!
New springs would bring it back up but the blocks are probably the cheapest fix and the easiest to install.
87 Silverado ½-ton 4x4 Longbed Pickup
350 TBI, 700R4 w/ Corvette servo
4" Skyjacker, 33x12.50s
14-bolt rear & Detroit coming soon
Offline Sierra4x4
« Reply #4 on: February 26, 2003, 07:40:00 pm »
good try kevin!
Offline jimfulco
saggy burban
« Reply #5 on: April 25, 2003, 01:07:00 am »
Mine sags too.  Maybe a big-block would even things up.
