Author Topic: Does 1980 Suburban 3rd seat fit Blazer 2nd????  (Read 9039 times)
Offline bartamos
« on: March 20, 2006, 10:31:00 pm »
will this work and what years of Blazer will it fit. this is the  Non folding seat. thank you.
Offline roundedline
Re: Does 1980 Suburban 3rd seat fit Blazer 2nd????
« Reply #1 on: March 21, 2006, 10:22:00 am »
Are you asking about the actual seat (minus mounts etc) or are you asking about removing the seat from a Burb and dropping it in a Blazer.  If it is the later, then no.  If the former I am not sure, but I have both so I can check for you...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline bartamos
« Reply #2 on: March 21, 2006, 10:23:00 pm »
I am asking if the seat and frame will physically fit when proper holes are drilled and it is bolt down. It must be too wide? or too high? right? thanks
Edited by: bartamos at: 3/21/06 10:23 pm
Offline roundedline
« Reply #3 on: March 23, 2006, 11:45:00 am »
I can check for you this weekend if you can wait.
I think the physical size is the same, you would just have to come up with the mounting...
Project Su
Jimmy 2WD Project
