Author Topic: 84 Suburban  (Read 17364 times)
Offline silver stepside
84 Suburban
« on: October 23, 2006, 08:41:00 pm »
I just got a '84 Suburban 3/4 ton 2wd for $350 in good running condition everything works and the body is in good condition. I have two questions.
1 When i apply the brakes coming to stop the seat belt light comes on and when i stop completely it goes out. There is no buzzer or braking problems just the light, what could cause that?
When i looked up the vin # in my   catalog the engine is a 350 heavy duty, what is the difference bwtween a 350 HD and a regular 350?
Thanx for ur time i'll post some pics tomorrow after work thanx Dennis
Offline toplessblazer
Re: 84 Suburban
« Reply #1 on: October 23, 2006, 09:52:00 pm »
Check the plug under the seat by the seatbelt to make sure there are no bare wires grounding out while you are slowing down.
Offline roundedline
Re: 84 Suburban
« Reply #2 on: October 24, 2006, 01:16:00 pm »
The HD motor will have a different cam and possibly slightly more compression that is more appropriate to pulling.  Otherwise an HD vs LD motor is identical (they do produce less power, but more down low.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Re: 84 Suburban
« Reply #3 on: October 24, 2006, 06:00:00 pm »
Thanx for the replys guys, i'm sure i'll have some more questions soon thanx Dennis. Here is a quick pic of the burb
not that great need to get a new camera soon.
Edited by: silver stepside at: 10/24/06 5:35 pm
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
84 suburban
« Reply #4 on: October 24, 2006, 06:47:00 pm »
Not a bad sub for that money--pretty cool.
SgtDel
91 sub
Offline occupant272
Re: 84 suburban
« Reply #5 on: December 31, 2006, 07:26:00 pm »
The HD "M" code 350 is a 4-bolt main I believe.  The K and L engines might be 2-bolt mains.
I just got an '84 Suburban myself, K20, 350/700R4.  $900.  But it's worth every penny, and we don't have to go make payments on it since it was a cash purchase.
Offline justpball
Re: 84 Suburban
« Reply #6 on: May 04, 2009, 12:16:21 pm »
I still cant understand why these burbs are so cheap, but it makes me happy, but the wifey sad... >:( cause I keep draging them home...
Offline bmaier
Re: 84 Suburban
« Reply #7 on: May 04, 2009, 05:31:13 pm »
Nice buy!
Re: 84 Suburban
« Reply #8 on: May 04, 2009, 05:34:54 pm »
this topic is like 3 years old..
Offline bmaier
Re: 84 Suburban
« Reply #9 on: May 04, 2009, 10:45:14 pm »
HA! ;D
Offline Jims86tpisub
Re: 84 Suburban
« Reply #10 on: June 25, 2009, 12:10:21 am »
The HD motor will have a different cam and possibly slightly more compression that is more appropriate to pulling.  Otherwise an HD vs LD motor is identical (they do produce less power, but more down low. <p><a href="mailto:captkaos@charter.net?SUBJECT=Forums 73-87 trucks">Chris Lucas</a>
<a href="http://www.73-87chevytrucks.com" target="_new">www.73-87chevytrucks.com</a>
<a href="http://www.captkaoscustoms.com" target="_new">www.captkaoscustoms.com</a>
<a href="http://www.captkaoscustoms.com/images/enginemock1.jpg" target="_new">Project Su</a>
<a href="http://www.captkaoscustoms.com/Jimmy/jimmywash.jpg" target="_new">Jimmy 2WD Project</a></p><i></i>
I think the HD has better(header type) cast exhaust manifolds too.
Jim
1986 K10 Suburban
Tuned Port Injection
193 Heads
Comp 260H cam
700r4 Raptor
Single exhaust with 2 Magnaflow Mufflers inline
