Author Topic: rear end/yoke  (Read 8116 times)
Offline missusv8
rear end/yoke
« on: March 30, 2007, 11:20:00 am »
Hi I have a 74 suburban with a 3 in the tree 2wd. I had a new rear end put in 6 mos ago and it blew quickly after. I was told it was the wrong one. So I had another put in and the u-joint doesnt line up with the yoke? I dont want to keep buying stuff that doesnt fit. Should I get another differential or try to get the right off set u-joint?  TIA
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: rear end/yoke
« Reply #1 on: March 30, 2007, 11:31:00 am »
Well, you have several options.
Pull the rear end yoke off the old rear to see if it will work on the new one
or:
grap the driveshaft off the donor vehicle--if it isn't long enough for your sub, you can take it to a shop and have it extended, or just get one made for the new rear--that'll match your tranny.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
