Author Topic: Totally new to the blazer's and have many questions.  (Read 9305 times)
Offline 1976Scottsdale
« on: December 14, 2005, 11:07:00 pm »
I have found a blazer here in NW Missouri where I live with no rust and one minor dent.  The thing has never seen mud.  Originally had a 305, which I currently own.  It now has a 3970010 casting hi nickel, hi tin content 350 engine.  The transmission is a th700r4 and the reverse and first are out of it, and it has an NP208 transfer case, which works fine.  I would like to put the thing back to either the original 305 and rebuild the 700r4(never done a 700 before, or any trans for that matter),or, I have a 375 hp 327 that I am currently rebuilding, I am going with a 4 bolt 350 block rather than the original LJ 327 block, to this I would bolt a th350.  Also have access to a DZ302 engine that I could use.  Looking for any ideas or suggestions.  Going to repaint back to original colors, basically just freshen up the original paint which is still decent.  Going to go with a 4 inch suspension lift and no body lift.  Has 10 bolt axles F/R.  It will be mudded once in a while, but will mostly be a daily drive while my 78 K-10 is being restored.
Offline toplessblazer
Re: Totally new to the blazer's and have many questions.
« Reply #1 on: December 15, 2005, 10:04:00 am »
This site is awesome and a lot of the topics and questions can apply to the blazers too. ck5.com is all about the 73-91 fullsize blazers and jimmys. Might check that out as well.
Offline roundedline
« Reply #2 on: December 15, 2005, 04:19:00 pm »
Welcome to the site.  We will try to answer you questions when you post them.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
