Author Topic: Exhaust fumes in cab  (Read 23569 times)
Offline 82BlazerMan
    • Blazer pics
« on: July 20, 2006, 01:42:00 pm »
Hey,
I'm getting exhaust fumes coming into the cab of my 82' Blazer.  The exhaust has been routed just behind the rear tires.  Is this possibly the problem?  What should I check for?
1982 Blazer 2WD
305ci
700R4
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Exhaust fumes in cab
« Reply #1 on: July 20, 2006, 08:28:00 pm »
Do you hear any exhaust leaks?  It should be audible.  How do you know it is exhaust fumes?
Could you have an oil leak or trans leak and fluid is dripping on the exhaust, therefore, smoke, smell, etc....??
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
Offline toplessblazer
« Reply #2 on: July 26, 2006, 08:19:00 pm »
Is the bed floor rusted out back by the tailgate? Also is your back window seal good? That would be my guess without knowing anything about you truck.
Offline 82BlazerMan
    • Blazer pics
exhaust fumes
« Reply #3 on: July 26, 2006, 08:26:00 pm »
I don't have any rust as far as I know, but should'nt it just flow out the back.  Oil leaks could be a problem though.  I'll double check.  I've oil leaks in cars before and it did'nt smell this bad.
1982 Blazer 2WD
305ci
700R4
Offline 123 pugsy
Re: exhaust fumes
« Reply #4 on: August 09, 2006, 06:04:00 am »
Interesting thing about the flow of the exhaust fumes.I had tailpipes dumping under my pickup somewhere around the rear axle. I was doing some work on the floorboards. I had a large pce. of floor cut out and stopped for the day.Drove to work the next day and I could feel the exhaust coming forward when I felt down through the hole(checked it when I smelt fumes). I believe it swirls around under the truck if it doesn't dump clear of the body. I installed longer tailpipes after I discovered this.
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
Re: exhaust fumes
« Reply #5 on: August 09, 2006, 05:07:00 pm »
Offline 82BlazerMan
    • Blazer pics
Exhaust
« Reply #6 on: August 14, 2006, 12:15:00 pm »
Usually with the windows down it seems worse, but I do still get a hint of it with them up.  I guess it creates a vacuum and sucks it in the back window maybe.  The seals stile seem to be good though.
1982 Blazer 2WD
305ci
700R4
Offline roundedline
Re: Exhaust
« Reply #7 on: August 14, 2006, 06:07:00 pm »
if your exhaust exits straight out the back, you will get alot of fumes pulled it.  It is best to turn them out the sides to eliminate this.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 82BlazerMan
    • Blazer pics
« Reply #8 on: November 25, 2007, 09:46:31 pm »
Well..............It's been a while since I've posted.  Well I found my exhaust problem.  Turns out it was my valve covers leaking oil and basically the fumes of the oil burning on the exhaust manifolds coming in though the vent.  I tightened them up, cleaned off the engine and most of the fumes went away.  Some times when I'm sitting in traffic, I notice a little, but most of it is gone.
1982 Blazer 2WD
305ci
700R4
« Reply #9 on: November 26, 2007, 10:45:10 am »
Wow, it has been a while.  Glad you found the problem.
Offline 82BlazerMan
    • Blazer pics
« Reply #10 on: June 10, 2014, 12:39:18 pm »
Well im back with more exhaust fume info. Turns out the blazer has a lot of holes in the tailgate. If you dont have a good inside window seal, the exhaust still seaps in. Oh and the holes are in the bottum where wires go through and the hinge attaches
Sent from my SAMSUNG-SGH-I317 using Tapatalk
« Last Edit: June 10, 2014, 06:39:18 pm by Captkaos »
1982 Blazer 2WD
305ci
700R4
Re: Exhaust
« Reply #11 on: June 10, 2014, 09:44:19 pm »
if your exhaust exits straight out the back, you will get alot of fumes pulled it.  It is best to turn them out the sides to eliminate this. <p>
     I have done this to eliminate the problem before, for some reason blazers do not like the exhaust that goes straight out the back.
Offline 82BlazerMan
    • Blazer pics
« Reply #12 on: June 11, 2014, 08:01:03 am »
I agree bake 74 and I did that years ago and it helped. The dangerous part is you think it helps but it doesn't get rid or the leak totally and its very easy to get used to the smell. At any rate ive filled the holes with foam rubber and I have the rear window seal on order
1982 Blazer 2WD
305ci
700R4
