Author Topic: Let's talk automatic transmissions...  (Read 6802 times)
Offline Kevin108
« on: January 30, 2003, 04:55:00 pm »
Based on what the guy I bought my truck from said, my 700R4 was rebuilt almost a year ago with a Corvette servo and torque converter.  It's already slipping, the 1-2 shift is nowhere near what it was in May.  I rebuilt the 700R4 in my S-10 twice.  The 2nd time I had the extra clutch packs added and a TransGo shift kit (Corvetter servo, springs, and valve body mods) but incessant problems (having it go out 3 times, always repaired under warranty but there was SOME problem every 2 weeks) with it led me to sell my S-10 and buy my fullsize.  So anyway, I think 700R4s are all pieces of junk.  I want to go to a turbo 350 or 400 but I don't know enough about the swap.  I have the NP208 transfer case.  I know the 700R4s have a lower first gear and losing overdrive's gonna suck but the cost of rebuilding it is twice that of a 350 and that extra $700 would go a long way towards paying for any extra gas I'd burn not having 4th gear.
So what do you guys think?
87 Silverado 4x4 Longbed Pickup
My Mods | Truck Pics | Kevin108@PavementSucks.com
Maker of 43 point turns!
Offline phaon1
Re: Let's talk automatic transmissions...
« Reply #1 on: January 31, 2003, 12:21:00 pm »
I may be the only spokesman for 700R4's on this board, so I feel I should speak my mind here.  I would just find a different tranny shop if I were you.  My 700R4 has spent 45K miles behind 400HP in a K10 with gastly abuse - offroading, dragracing, and manical street driving - I've even pulled trailers in overdrive (just like you're not supposed too).
Granted, my 1-2 shift will chirp all four tires and my 2-3 (at around 70mph) will still spin the back tires.  I do get slambed around a lot during normal daily driving.  But I average 13.5 mpg with highway mileage as high as 16.  Now I spent almost $3000 on this tranny.  That may seem crazy, but that extra money has almost paid itself back over the past three years in what I have saved in gas money.  My tranny has outlived a cam, timing chain, torque converter, two rearends, u-joints, brakes, and numerous engine and crossmember mounts.  It is still performing like the day it went in.
Since I don't remember you have a bunch of mods on your engine, I'm thinking a good $1000 rebuild would outlast just about every other moving part on your truck.  And if you plan on putting a lot of miles on your truck, the cost will eventually be worth the extra mileage.
Chris
1981 GMC K10 – 75K miles on original parts (what few are left)
Exterior Mods –
- Royal Blue chameleon paint
- 15X11 Craiger chrome wheels
Interior Mods –
- B&M Light Truck Mega Shifter
- Grant steering wheel
- 6 Auto Meter Ultra Light gauges in dash, 2 on a-pillar
- Keyless entry
- Billet dash and door trim
- Solid headboard with four built in speakers
- Sony Mobil ES CD Deck, MTX truck boxes, Jensen AMP
Drivetrain Mods –
- GM Racing ZZ4 Engine with H.O.T. Cam kit, 150 amp alternator, PeteJackson Gear Drive
- Hooker SS headers, 2 1/2" SS exhaust, Dr. Gas x-pipe, Flowmaster 2 chamber mufflers
- K&N X-Stream lid and 14" air cleaner.
- Coan 3000RPM custom built torque converter
- Built-up 700R4 transmission
- Yukon 4.11 gears with titanium pins in stock 10 bolt front and 12 bolt rear.
- Eaton heavy duty locker.
Offline Kevin108
« Reply #2 on: January 31, 2003, 04:29:00 pm »
Oh yeah, all 3 trannies have been serviced by different shops.  The first stock rebuild was $950, the 2nd was $1300 w/ the shift kit and extra clutch packs, and the 3rd was done by a guy that builds trannies for drag racers and was done before I bought the fullsize.  $3000 is too much for any one part of an old truck like mine.
Edited by: Kevin108 at: 1/31/03 5:34:11 pm
Offline 73K20
« Reply #3 on: February 03, 2003, 08:42:00 am »
The TH350 will be a direct replacement for the 700R4.  I believe that the two are only about 3/4" differnet in length.
1973 K20 - 350/350/205
Offline Kevin108
« Reply #4 on: February 03, 2003, 04:36:00 pm »
That's good news!  Now I've gotta find a core...
