Author Topic: T-case  (Read 6297 times)
Offline nilock10
T-case
« on: February 21, 2003, 07:01:00 pm »
i have an '81 K10 with the np205, for some reason when i put it in four-low olny the rear tires spin. they all spin in four-high so i thought that maybe the T-case needed to be rebuilt but im not sure. i don't no alot about t-cases so i way wondering if it was soposed to do that or if there was some thin wrong with my t-case. if it is soposed to be like that is ther a t-case that spins all four tires in four low.
Edited by: nilock10 at: 2/23/03 10:03:34 pm
Offline 79SilveradoK30
T-case
« Reply #1 on: February 23, 2003, 09:38:00 pm »
If only two wheels are spinning, then you should be in 2WD. I'm pretty sure the NP205 is a part-time 4WD t-case, so the t-case shifter might be worn or something, and you may be putting it into 2WD instead of 4WD low.
nilock10
  • Guest
t-case
« Reply #2 on: February 24, 2003, 09:46:00 am »
all of the other gears work. 4hi and 2hi. i put the stifter all the way forward and the engine revs high so i no its in a low gear but olny the back tires spin.
