Author Topic: 4wd conversion front end lift???  (Read 7034 times)
Offline bs300ex5
« on: March 13, 2003, 06:06:00 pm »
hey i'm lookin at a 1978 cheyenne 1/2 ton and it is titled as a two wheel drive but it has a 4wd conversion in it... anyone know anything like if these are dependable and i am wanting to lift the front to match the back cause they sit weird... will this throw the front out of wack or what ... thanx
Offline smokin77
Re:4wd conversion front end lift???
« Reply #1 on: March 13, 2003, 08:37:00 pm »
Is it a conversion kit, or did the guy put a 2WD body on a 4WD frame?
Offline 79GMC4x4
Re: Re:4wd conversion front end lift???
« Reply #2 on: March 18, 2003, 10:14:00 pm »
I'm with Smokin.  I suspect it was only a cab swap.  If so, the lift will be a snap.  Normal procedure.
'79 GMC shortbed 454 th400 14 bolt FF NP205 Dana 60
Offline DFWP8ntballCwby
RE: 4wd conversion
« Reply #3 on: April 18, 2003, 05:08:00 am »
A conversion can be done, but it is a real pain in the neck, so it's highly unlikely that is the case with your truck.  I have done 2, and both of them were on crewcabs, simply because they were hard to find in the area in 4wd.   You can find a 4wd half-ton, oh, anywhere...  LOL
Conversion
« Reply #4 on: April 18, 2003, 06:14:00 am »
I just talked to a budy of mine and he was telling me that a kid down the road from him converted a two wheel drive frame to fourwheel drive and can't understand why the back end sits lower. The shackles for the rear springs are shorter on a two wheel drive.
