Author Topic: Vortec Heads  (Read 6250 times)
Offline lions762004
Vortec Heads
« on: July 01, 2003, 11:10:00 pm »
I am rebuilding a 350 to go in my 1985 4wd and I am thinking of using some Vortec heads on it. What I need to know is how much would a set of used ones cost and where I can find them? Any info would help and I'm on a tight budget.
Offline Sierra4x4
Re: Vortec Heads
« Reply #1 on: July 18, 2003, 11:21:00 pm »
anyone? id like to know too. I figure my next BIG add on will be some heads.
Offline 73K20
Re: Vortec Heads
« Reply #2 on: August 01, 2003, 07:49:00 am »
I have been looking into this for my engine build up.  GM Performance wants about $550 for a set of complete new Vortec heads.  I would say that around $300 would be about right for used heads.  As a note, you should replace the valve springs on stock Vortec heads.  They dont work well with carburated cams in these older engines.
1973 K20 - 350/350/205
Offline cimfth
vortec intake
« Reply #3 on: August 19, 2003, 10:08:00 am »
I think you have to buy a vortec style intake if you switch to vortec heads. In Jegs a vortec intake is about $300. I think it would be a pretty good idea. I thought about doing it myself.
Offline 1973 500
heads
« Reply #4 on: December 05, 2003, 04:00:00 pm »
In Jegs, they have brand new vortec cast iron heads, they run $256.99, and they also have aluminum vortec heads, which run $599.99, but if I were you and went the aluminum route, I'd get a set of edelbrock e-tec series heads which are a vortec design but better and cheaper than gm.  The e-tech run $519.99 for 170/65cc ports, and $549.99 for 200/78cc ports.  The GM manifold is a little pricy, so I'd go with an edelbrock vortec manifold for $173.99, that's for the performer rpm which will mate up to a square bore.
