Author Topic: Front Driveshaft angle  (Read 5474 times)
Offline 1HITRUK
« on: February 29, 2004, 01:42:00 am »
1980 GMC Sierra with a 12 inch Superlift and I am havin a little problem with the front drive shaft.  the angle is so much that i dont know how to hook up the drive shaft from the np 205 tcase to the front axle.
Edited by: 1HITRUK at: 3/15/04 8:13 pm
Offline aprice
front driveshaft angle
« Reply #1 on: March 16, 2004, 12:30:00 am »
there are two things you can do. 1. cut the spring mounts off the axle, and tilt the axle to decrease the angle rewelding the mounts back on, or 2. you can find or make shims to change the angle of the axle without cutting and welding
Offline ratblock
Re: front driveshaft angle
« Reply #2 on: March 16, 2004, 09:46:00 pm »
I dont think you could cut the  spring mounts off the left side because they are machined rite into the differential housing.Plus if you turned the axel without pulling the tubes out of the housing and rotating them back to normal position you cant get the front tires to align properly.I would go to High Angle drivelines web site and see what they have to offer.[ But it wont be cheep.]
77 swb 468 4l80e np205 d60f 14bolt rear
71 blazer 383 th350 np205 d44hd front d60 rear
