Author Topic: Will the drivetrain combo fit??  (Read 5358 times)
Offline chaserooooo69
« on: March 26, 2004, 03:17:00 pm »
i have a 1980 K5 Blazer that the body is smashed up but the drivetrain is in good condition i have a 78 pickup that is in good shape but no drive train the cab came from a two-wheel drive truck but is now on a four-wheel drive truck. other than needing new driveshafts will the chevy 350, th350 and np205 drivetrain work with this combo?? also the stock axles from the blazer i'm going to use any info you guys can provide me to make this job easier would be a great help.
Offline 86 4x4
drivetrain
« Reply #1 on: March 26, 2004, 03:47:00 pm »
Yes the drivetrainwill work.Almost everything is iner changable.good luck on the changeover.You will be able to use the front driveshaft from the Blazer if you are staying with the same gear.
Dwayne
