Author Topic: np203 operation instructions  (Read 6420 times)
Offline wild03
« on: March 02, 2004, 11:42:00 pm »
Almost ready to take my GMC truck for a spin, I've never own a 4x4 before and was wondering on what the procedure is for t-case operation, Do I have to put the transmission in park, neutral, etc?
Thanks!
Offline aprice
re np203 operation
« Reply #1 on: March 03, 2004, 10:22:00 pm »
you can shift in to 4-wheel drive in any gear. although the tires shouldnt be spinning outta control, or above 45 mph. you can operate above 45 but not recomened. if you want to use the low range, you should be at at complete stop when shifting to low range.
Offline 86 4x4
Re: re np203 operation
« Reply #2 on: April 04, 2004, 10:31:00 am »
Yes you can shift the t-case in any gear but it is easiest to shift when you are in neutral.
Dwayne
