Author Topic: auto to standard  (Read 10446 times)
Dan
  • Guest
auto to standard
« on: January 21, 2002, 09:35:00 pm »
I have a 79 auto 4x4 3/4 ton I would like to make a standard so I can put a wrecker on the back. I am new to 4x4's. I have another 1/2 ton 2wd that is a standard to donate parts. Can I do this or am I going to run into problems. will the transmission bolt to the transfer case? Or is it possible to run a pto from an automatic somehow?
Any help wpuld be greatly appreciated.
Offline 1979blazer
hi
« Reply #1 on: January 22, 2002, 01:14:00 am »
good stuff
Edited by: 1979blazer at: 4/21/04 11:56 pm
Offline 83chev4x4
Re: auto to standard
« Reply #2 on: January 22, 2002, 12:40:00 am »
I have a 83 chevy 4x4 with a 700r4 tranny and 208 t-case I would like to put in a four speed with a 205 t-case. exactly how hard is it to do the conversion? how long would it take aprox.? i do not have a donor vehicle. thanks
Blazin
  • Guest
PTO
« Reply #3 on: February 15, 2002, 09:57:00 pm »
Why not run the PTO off the tranfer case? I have had more chevt trucks than I can count. Most of the older ones had pto plates ont the tranfer case.
Offline RegulatorInqInq
Hey Blazin.....
« Reply #4 on: February 16, 2002, 08:22:00 am »
just out of curiosity how exactly would you set that up?
Offline 85ChevyTow
Re: Regulator
« Reply #5 on: February 27, 2002, 12:06:00 am »
You would need a 205 t-case.It seems like the 203 has a pto opening also, but i'm not sure.You need the proper pto to fit the t-case.If I remember correctly, you need the t-case in neutral,the tranny in drive or 3rd(manual tranny) to operate the pto.
Offline 85ChevyTow
Re: Dan
« Reply #6 on: February 27, 2002, 12:42:00 am »
What type of winch/wrecker body do you have?Is it pto or hydraulic?I've been in the wrecker business for about 10 years & have built 2 trucks myself.I may be able to help you with a little more info.Also the 2wd 4spd would need the output shaft replaced plus the adapter and your t-case would need the input shaft replaced.I recently traded a rebuilt turbo350 with a shift kit & a rebuilt 205 case for a used 4spd & a 205 even swap.You might look in a local junkyard for a 4spd/205 & swap them your auto.Even if you have to give them a little boot,the 4spd would be better.By the way, I hate autos.You can keep the auto if you put your pto on the t-case, or you can go elec. like some said earlier.
Edited by: 85ChevyTow at: 2/27/02 6:50:50 am
Offline ckuper
Re: Dan
« Reply #7 on: March 21, 2002, 12:39:00 pm »
hey i have a 1985 4x4 3\4 ton truck and i have the special chevy towing transmisson and i need more speed on the open road. i am thinking about a bolt on overdrive or a 4 speed manuel.
i need help with this
thanks
Offline 85ChevyTow
Re: ckuper
« Reply #8 on: March 24, 2002, 12:30:00 am »
I'm not sure, but I assume you have a turbo 400 tranny.If so a 4 speed manual will not help you with your top speed. You could swap in a 700r4 overdrive in, but you will probably have to change driveshafts. Also there is a lt. duty 4 speed overdrive manual tranny, but they are rare. I've been in the towing biz for 10 years and I've only seen one, its in a 82 k-10 diesel p/u I have for parts.You might be better off with the bolt on overdrive.
Offline ckuper
Re: ckuper
« Reply #9 on: March 25, 2002, 12:11:00 pm »
hey thanks for the information. Do you know where i can find one for a good price?
Thanks
Offline barry350
Re: hi dan
« Reply #10 on: April 07, 2002, 08:42:00 pm »
any pics of your beaver tail? im building a body on my one ton and any pics would be helpfull. thanx
