Author Topic: shifting to low 4x4  (Read 5733 times)
Offline zooracer
shifting to low 4x4
« on: September 29, 2004, 12:46:00 pm »
I have an 81 with the full time hubs.
I can easily shift down to 4 high, but it will not go down from there to 4 lo.
Any suggestions?
matt
Offline bigblue86
Re: shifting to low 4x4
« Reply #1 on: September 29, 2004, 09:45:00 pm »
did you check your linkage at the transfer case?
I used to have a 79 blazer with full time and the linkage got loose once and gave me similar problems
Offline zooracer
« Reply #2 on: September 30, 2004, 09:13:00 pm »
Ok, will check the linkage out.  Maybe just try to adjust it...
Thx
Offline biggmcguy
« Reply #3 on: November 27, 2004, 12:08:00 am »
make sure that when you shift to 4 lo that the tranny is in neutral
