Author Topic: Gearing Problem?  (Read 5285 times)
Offline Olaf73
Gearing Problem?
« on: January 18, 2005, 01:02:00 am »
My Girlfreind just scored a 73 Chevy pickup(Crate 350, SM465, NP205, 4" Lift, 35's).  When in 4H or 4L, the rear end chirps alot, like the gears in the axles are different.  I dont think its a locker, because it does it at idle, in a straight line.  After, its a pain to get it out of gear.  The front has a tag that says 41.11-3.73, what ratio is this that?
Offline roundedline
Re: Gearing Problem?
« Reply #1 on: January 18, 2005, 10:26:00 am »
Offline Olaf73
« Reply #2 on: January 18, 2005, 05:05:00 pm »
Ya, the rears chirp like if you were cornering with a locker.  We even took it out to the dirt, same thing.  I think im gonna have to pull the covers and check the gears.
Offline BigBowTie75
« Reply #3 on: February 23, 2005, 04:51:00 pm »
check the gears it souns liek they have different gear ratios cuz my first chevy did that some one had a 3:55 i nthe rear and a 3:73 front
Offline 1984 K20
« Reply #4 on: February 23, 2005, 09:47:00 pm »
As for your question about the tag on the front. If you were still wondering, it means 41 teeth on the ring gear divided by the 11 teeth on the pinion which is approximately a 3.73 gear ratio.
Edited by: 1984 K20 at: 2/23/05 9:55 pm
« Reply #5 on: February 25, 2005, 09:24:00 am »
When i first got my Balzer it did that and ended up tossing a drive shaft into the floor the first trip out. It had 3:73 in front and 2:73 in the rear.
