Author Topic: trucks leanin  (Read 4339 times)
Offline cityoforphans
trucks leanin
« on: April 15, 2005, 04:17:00 pm »
i have a 86 k20 and its leaning to the left. the springs are good. i cant figure out whats wrong, it has a 4 inch suspension lift and a 3 inch body lift. i was on flat ground when i checks so i dont know whats wrong.
Offline Denis
Re: trucks leanin
« Reply #1 on: April 17, 2005, 09:10:00 am »
have you checked body mounts, etc?
Re: trucks leanin
« Reply #2 on: April 18, 2005, 09:39:00 pm »
yeah i checked body mounts, 2 are alright on the back of the cab. but the box is also leanin, so it would be un even. the only thing i can think of is im always on un even ground which i know im not.
Offline roundedline
Re: trucks leanin
« Reply #3 on: April 19, 2005, 08:59:00 am »
No vehicle is going to be perfectly level.  The nature of a spring is going to allow it to "set" at a different heights.  You could measure a new car on the showroom and it would be at different heights.  Then measure it after someone drove it and it would be lower.  Same goes with lift/lowering kits, the 4,5,6" lift/drop is a general term, you could get less or more depending on how the spring sets.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
