Author Topic: Gear swap or not?  (Read 6501 times)
Offline truck1974
Gear swap or not?
« on: December 05, 2005, 03:57:00 pm »
I recently bought a 79 chevy dually crew cab 4x4.  Has 454, 4spd, 205 T-case, Dana 60 front axle,  Dana 70 rear.  Before I bought it I was told by the owner that someone before him had changed the rear end gears out.  The truck was originally 4.10 gears all around.  For whatever reason someone left the 4.10's in the front and put 3.73's in the rear.  He said he never needed 4wd and just used the truck to pull a large fifth wheel camper in the summer.
Anyway I can't obviously use the 4wd until I swap the gears out.  I'm wondering what you guys think.  Should I leave the rear end 3.73's and swap the front to 3.73's also or should I leave the front alone (supposedly 4.10's) and get 4.10's for the rear?
I suppose it's personal preference on what gear to use.  Would I notice much of a difference either way?  Right now the truck has 235x85x16 inch tires which are about 31.7 inches tall.  I'm gonna stay real close to that size, maybe up to a 33" tire but no bigger than that.  I was just wondering with the factory tires probably being about 31 inches tall and original factory gearing being 4.10 if I should go with the 4.10's?
My buddy said with all the torque of the big block I wont see a noticeable change in the two ratio's anyway.  What does everyone else think?   I usually don't pull heavy trailers too often.  I just have a race car/trailer to pull and might see some other heavy stuff once in a while.  And I only get about 6-7 mpg now so I know fuel economy isnt the issue.  Just want to know If you guys think I'd be more in my powerband with 4.10's.  Okay enuff rambling I'm ready for some input.  Thanks for your replies as always.
Matt
Offline roundedline
Re: Gear swap or not?
« Reply #1 on: December 05, 2005, 03:10:00 pm »
I would put 4.10's back in if you are going to go with 33's, but it is your call.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Snuke87chevy
« Reply #2 on: December 05, 2005, 10:26:00 pm »
I'd go with the 3.73's, since you are not doing a lot of heavy pulling.  Increasing tire size to 33's shouldn't affect how it runs since it has a big block, and you'll also be able to run faster on the road without having the RPM's way up there.
Offline truck1974
« Reply #3 on: December 13, 2005, 11:46:00 pm »
1 for each......nobody else?
Offline DieselTech
re:
« Reply #4 on: December 14, 2005, 07:00:00 pm »
I had 3.73's in my 78 3/4-ton with 33's on it, and it was fine...even pulling a trailer. Find a gear ratio/rpm calculation chart on a 4x4 parts website and do the math for yours, to be sure. www.4wheelparts.com has one. BTW, mine is not a big-block, so yours would probably be A-ok with the 3.73's.
Offline Gutter Runner
« Reply #5 on: December 20, 2005, 08:21:00 am »
I have a 76 1/2t 4x4 with a tired 350. 4:10 gears and 35's. All the grunt you would ever need. If you dont plan on doing alot of heavy hauling or off roading, I would probably go with the 3:73's if you are going to be running the stock size tires. I think even if you went up to the 33's you would have plenty of power with a big block. Your call.
