Author Topic: SPEEDOMETER GEAR CORRECTION  (Read 3710 times)
Offline jimmy3fan
« on: February 01, 2006, 08:50:00 pm »
I JUST REPLACED THE 3.08 GEARS IN MY 87 1/2 TON 4X4 WITH 3.73s. ANYONE KNOW WHAT SPEEDOMETER GEAR I NEED TO CORECT THE SPEEDOMETER? ITS A 700R4 WITH A 208NP
Offline roundedline
Re: SPEEDOMETER GEAR CORRECTION
« Reply #1 on: February 02, 2006, 11:12:00 am »
Check to see if this helps you.  Typically you can go to GM dealership and they can help you.
www.73-87.com/7387garage/...speedo.htm
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 2/2/06 11:12 am
