Author Topic: divorced transfer case  (Read 19568 times)
Offline TRUCK6DRIVER
« on: March 18, 2006, 09:28:00 pm »
Is anyone running a divorced transfer case? I have aquired 2 NP200 cases. These are the series before the NP205. The difference is the gears are straight cut and a bit noiser. They are out of a military M715's and have the right hand drop like the GM trucks need. Since you can put these behind any 2wd transmission I thought it would be a good case for our series trucks for off road use. What do you think?
RH
Offline 1976Scottsdale
Re: divorced transfer case
« Reply #1 on: March 19, 2006, 08:28:00 am »
Could be.  You would have a wider option to transmissions.  I had a friend who ran a divorced case with an M-22 rock crusher from a chevelle.  It was pretty darned quick for a 4.56 gear shortbed.
« Reply #2 on: March 19, 2006, 08:51:00 am »
I am in the process of aquiring a 2 1/2 ton Rockwell from a early sixties dodge log truck to run in my next Blazer project. It is divorced and already twin sticks. I am still looking for an old Lull / Petibone off road fork lift to rob the axles from.
« Reply #3 on: March 19, 2006, 01:27:00 pm »
If you want an NP 200 I have 2 spare I can make you a deal on one if you would like.
RH
« Reply #4 on: March 19, 2006, 01:30:00 pm »
« Reply #5 on: March 20, 2006, 08:19:00 am »
NP 200 is not strong enough, but thanks anyway. To much money for axles. I am looking for one that dosn't run or has already relived of engine, transmision, lift, or something, so I can but just the axles. Plus to far away, I am in N.H.
Edited by: Blazin at: 3/20/06 8:20 am
