Author Topic: rear spring hanger  (Read 4798 times)
Offline CBell
rear spring hanger
« on: May 15, 2006, 12:04:00 am »
yeah i just bought my first chevy pickup from a friend and pretty much was completly apart and when i was putting it back together I noticed that the spring hanger had been cut so the shackle would come out of the bottom of the hanger. I forgot to add that the truck has a four inch lift and my freind did this instead of putting the block under the leafs. is this wise to run the truck like this or should i get some new hangers and go with the block under the leaf.
Re: rear spring hanger
« Reply #1 on: May 15, 2006, 07:43:00 am »
Not quite sure what you mean but sounds to me like a caveman move. I would run blocks or get lift springs.
Offline roundedline
« Reply #2 on: May 15, 2006, 05:21:00 pm »
It is a Shackle Flip.  It lifts the truck up higher without having to use blocks that actually cause axle wrap, or lift springs which are going to be a stiffer right.
I know of people who have done this and run the truck this way and wheel on it.  If it was done properly, it isn't going to be an issue..
www.coloradok5.com/shackleflip.shtml
Here is an actual KIT that does the same thing...
chevy.off-road.com/chevy/...?id=200792
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #3 on: May 15, 2006, 10:29:00 pm »
Oh O.K., when he said it was cut out it sounded like a home brew setup!
Offline roundedline
« Reply #4 on: May 16, 2006, 09:17:00 am »
Probably is considered a home brew setup now that an actual company produces it...
This is why alot of 4x4 owners are looking for 4x2 front hangers, so they don't have to purchase the kit.
Project Su
Jimmy 2WD Project
