Author Topic: Th-350 fluid capacity  (Read 10868 times)
Offline chevythunder
« on: September 05, 2006, 08:01:00 pm »
I am changing the fluid and filter on my turbo 350 tranny..i was wondering if anyone knew the exact capacity.. thanks...-
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
th350 fluid
« Reply #1 on: September 05, 2006, 08:14:00 pm »
Do you have an external cooler??  If not, I could be wrong, but it should be about 4 quarts.  Buy an extra just in case for later if nothing else.  I usually get those big containers that have like a gallon or so of dexron III
Edited by: SgtDel  at: 9/5/06 7:17 pm
« Reply #2 on: September 05, 2006, 08:35:00 pm »
there is a tranny cooler built into my radiator if that is what you call external...anyone know if there is a date on transmissions anywhere that indicates the year it was made?
Offline 79ChevyK20Guy
  • The clothes don't make the man!
Re: Th-350 fluid capacity
« Reply #3 on: September 07, 2006, 01:14:00 pm »
Fluid capacity for a th-350 with a fluid change is 3 to 5qts complete drain and refill is 12 qts.
Brian Skaggs
"Sometimes you just gotta say WTH?"
