Author Topic: Headers on a 4x4?  (Read 5963 times)
Offline JohnnyGixxer
Headers on a 4x4?
« on: July 07, 2006, 12:17:00 am »
I had my mechanic install some headers on my project truck. My old 1973 Chevy 3/4 ton long bed. The passenger side header ends right at my front drive shaft ! He is talking about takeing out a " bracket " that is right there to make some room. Has anyone overcome this problem? Or should i just but the stock exhaust back on?
I reposted this here because it wasnt getting any replies in the preformance forum.
Re: Headers on a 4x4?
« Reply #1 on: July 07, 2006, 12:00:00 am »
Stock exhaust shouldnt fit. You should get a dual kit for headers. I have never had to remove any brackets etc. for headers to clear.
Offline roundedline
« Reply #2 on: July 07, 2006, 01:10:00 pm »
Some low quality headers for 4x4's end up right at the front shaft.  Typically people have heated them up with a pipe in the end and bent it over.  I haven't done this.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 79 4x4
« Reply #3 on: July 22, 2006, 02:49:00 am »
mine bumps the front passenger shackel under hard accereration
79 Chevy K-10
4" lift, 33's, 350sbc
88 Turbocoupe
92 Explorer (working on 2.3T swap)
my site
my cardomain
Offline 75Chevy4x4
re: headers on a 4x4
« Reply #4 on: September 07, 2006, 05:44:00 pm »
I just had some installed on my 75 1/2 ton long bed with no trouble. They are Hooker Competition long tubes...
Offline 1976Scottsdale
headers and mystery bracket
« Reply #5 on: September 07, 2006, 10:50:00 pm »
Your Mechanic is most likely talking about removing the transfer case suoort rod that runs from the bellhousing to the side of the transfer case.  This is a common thing to have to do.  Mine has the bracket removed, don't know if it has to be though, it was already gone when I bought the truck.  I have had no problems yet.  Try the hooker Competition series headers.  Heddmans I would not recommend.  The fact that the Hooker headers allow on the change plugs without a 5/8" wrench might have something to do with that point of view.
Offline CruzinHigh
  • Chevy 4 life
Re: @#%$ @#%$ mystery bracket
« Reply #6 on: September 16, 2006, 11:01:00 am »
I have the cheap Summit brand (really made by dynomax I am told) and they don't hit any brackets.
Sounds like heating the end a bit and bending is a good idea.  I wouldn't remove any support brackets unless you really have to!
Mike Carter
1986 Chevy K-10 4x4
