Author Topic: Replacing front shackles  (Read 4097 times)
Offline Welshboy
« on: October 16, 2006, 12:31:00 pm »
I've bought some heavy duty front shackles from Offroad Design to replace my worn ones.
My question is, do I have to remove the U bolts or can I just support the axle and do it that way?
Thanks
'78 K10 Scottsdale, 6" spring lift on front.
Offline roundedline
Re: Replacing front shackles
« Reply #1 on: October 17, 2006, 05:02:00 pm »
You don't have to remove the axle from the springs to replace the shackles.  You will have to lift and support it though so it won't be under tension...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
