4 Wheel Drives
shifting to low 4x4
Topic: shifting to low 4x4 (Read 4339 times)
zooracer
shifting to low 4x4
September 29, 2004, 12:46:00 pm »
I have an 81 with the full time hubs.
I can easily shift down to 4 high, but it will not go down from there to 4 lo.
Any suggestions?
matt
bigblue86
Re: shifting to low 4x4
September 29, 2004, 09:45:00 pm »
did you check your linkage at the transfer case?
I used to have a 79 blazer with full time and the linkage got loose once and gave me similar problems
zooracer
September 30, 2004, 09:13:00 pm »
Ok, will check the linkage out. Maybe just try to adjust it...
Thx
biggmcguy
November 27, 2004, 12:08:00 am »
make sure that when you shift to 4 lo that the tranny is in neutral
4 Wheel Drives
shifting to low 4x4
