Author Topic: Ignition Switch sticking.... Gone Bad?  (Read 21396 times)
Offline Ziptar
« on: March 11, 2006, 06:50:00 am »
I was working on the 79 today and I noticed that the ignition switch is sticking, it doesn't return back srom start. I have to turn it back myself. What's worse I think the noise that I thought the tranny was making is actually the starter running, not sure though, noise goes away in drive, but when I put it in Park or step on the brake with it in drive the noise comes back.
I also thought my Temp gauge was bad it would peg on HOT, when I was fooling with the ignition switch I could finagle the key back far enough to get the gauge to read correctly, so again I think It's stuck in start. More often than not I'll turn the key back too far and the truck shuts off.
I sprayed some WD40 into the lock cylinder and it made a slight difference but it still doesn't spring back from the start position.
Any Ideas??
Offline 123 pugsy
Re: Ignition Switch sticking.... Gone Bad?
« Reply #1 on: March 11, 2006, 03:48:00 pm »
Be careful.I had this problem and it got stuck in the run position when a friend was using my truck.It definitely is toast.
ended up putting a toggle and a push button on it.
Pugsy
76 C10 LWB
TPI 350
Offline alhrensblade
« Reply #2 on: March 12, 2006, 08:23:00 am »
Heh, I had the same thing happen a while back, had to stall my '78 for a week before I could get a replacement (my only ride at the time). I /highly/ recommend getting it replaced before it sticks completely, as they're a b**** to remove if they're jammed in run.
Offline Mr Diesel
  • Aaron
ignition switch
« Reply #3 on: March 14, 2006, 08:28:00 pm »
Probably your ignition switch located on top of the steering column underneath the dash. It is very inexpensive and easy to replace. Remove the two bolts under the dash that hold the column up and you will be able to lower the column enough to access the switch. Think I paid like $15 for a new one on my '76.
- Mr Diesel
'76 C30 Crew 6.2
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline ChevyGuy
ignition switch
« Reply #4 on: March 14, 2006, 11:57:00 pm »
Its most likely the key cylinder thats sticking but also check the box and the rod on the steering column.
Offline cooltoolguy
Re: ignition switch
« Reply #5 on: March 15, 2006, 10:01:00 pm »
My 86 did the same thing 3 months ago and my 94' last summer, I couldn't get the keys to go all the back to get the key out.  I fiddled with it and it finally came out.  I went to chevy  and $28 bucks later had a new cylinder.  when i took the old one out it just about fell apart it was so worn.  replace it while you can still move it because when it gets stuck it wont' be so easy.
Offline Ziptar
Re: ignition switch
« Reply #6 on: March 16, 2006, 05:16:00 am »
Thanks for the info eveybody. Looks like I'll be pulling it this week end.
1979 Silverado C10 w/ Olds 5.7 Diesel
85 C10 Custom Deluxe
