Author Topic: Right Turn Signal not blinking but all bulbs are on??  (Read 12620 times)
Offline Ziptar
« on: March 18, 2006, 07:11:00 pm »
My Left Turn Signal blinks just fine but the right just stays on. I checked dthe front, rear, and side marker bulbs and they are all on.
Any Ideas? Bad Ground on one of the lights maybe??
1979 Silverado C10 w/ Olds 5.7 Diesel
85 C10 Custom Deluxe
Offline 123 pugsy
Re;Right turn.....
« Reply #1 on: March 18, 2006, 06:44:00 pm »
Try changing the flasher at the fusebox.
Pugsy
76 C10 LWB
TPI 350
Offline shaved80
Re: Right turn.....
« Reply #2 on: March 18, 2006, 07:40:00 pm »
it may be a bad ground like you said
Offline Food Dude
Re: Right Turn Signal not blinking but all bulbs are on??
« Reply #3 on: March 19, 2006, 10:25:00 am »
Try Changing the bulbs also, I had one once that the filament broke but was touching the other filament and still lit up!
Offline Ziptar
« Reply #4 on: March 19, 2006, 10:44:00 am »
I just went out and swapped flashers between the 85 and the 79. Blinkers now work in the 79 (albeit they blink quicker on both the left and right sides.) The 79's flasher works fine in the 85, so I thought loose flasher and swapped them back, nope.. No dice didn't work in the 79. So I swapped again they are both working..
Go figure...
Offline 81ChevyCheyenne
Now I got a reason!
« Reply #5 on: March 19, 2006, 04:02:00 pm »
I knew there was a good reason for having 2 bowties! Now, will the wife buy it?
81ChevyCheyenne:D
Offline Ziptar
Re: Now I got a reason!
« Reply #6 on: March 19, 2006, 05:39:00 pm »
No.. In fact she just commented that she'd like to see me seel one as apposed to junking one.. But, To be honest, I just want to put the other back together.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #7 on: March 19, 2006, 09:23:00 pm »
You can't have too many trucks.  After putting a 383 stroker in my 79, the stork visited us and had to go buy my 91 suburban.
I kinda like having a choice of rides whenever I wish.
SgtDel
George Mason upsets UNC!!! SWEET 16 baby!!
GMU '90
