Author Topic: steering column wires  (Read 6190 times)
Offline 83silverado
« on: March 29, 2006, 09:28:00 pm »
In the continuing saga of my hacked up truck, I realized that I have no hazard flasher switch.  This is usually on the steering column, correct?  The pull-up round knob?
Well, the guy must have had a column problem, because there is a cut out spot.  Underneath, there is a set of 4 very small wires, almost like a ribbon cable.  They rundown the column to a connector under the dash, and then into a bigger harness.
Any ideas what this might be for?  Is this my hazard light wiring?
Offline Z28 c10
Re: steering column wires
« Reply #1 on: March 30, 2006, 08:50:00 pm »
Most of the time that small ribbon is cruise control wires.
 JayTater
 Z28 C10
Offline RSBAD454
Column Wire
« Reply #2 on: March 31, 2006, 09:21:00 pm »
I concur, that would be for the cruise control.
http://
