Author Topic: drivers side lock stuck  (Read 8225 times)
Offline 87chevycustom
« on: April 23, 2006, 06:46:00 pm »
the lock on my drivers side of my 87 custom deluxe frequently gets stuck locked and i have to get in the passenger side. any body no how to easily replace the lock or fix this problem? and i have already tride lube
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #1 on: April 23, 2006, 07:11:00 pm »
You have to take the door panel off, obviously.  You can then see the lock rod going from the lock stem inside, down to the key lock.  This may have bent or need adjustment.  If you have to replace the actual key lock, it is simply held in place by a C clip.  Take some pliers and remove the C. Slide it out.  The key part will then fall from the outside of the door.
My 79 does that,,,, i have to jiggle the key if i try to unlock w/ the key.  I know it needs to be adjusted. If i have to replace the actual lock cylinder, i would need a new key, which sucks.
SgtDel
Offline 123 pugsy
Re: > drivers side lock stuck
« Reply #2 on: April 24, 2006, 05:21:00 am »
You don't need a new key.If you buy from GM they can match your new lock to your key.(well this was a few years back.Not so sure about now.)
Pugsy
76 C10 LWB
TPI 350
Offline 79apache
« Reply #3 on: April 26, 2006, 07:15:00 am »
Mine occasionally does that too.  I free it by pushing in the outside door latch button. I have no idea why this works...  The inside latch will not fix it, only the outside.
Great fun when the pass. door will not open for friends and family!!!
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #4 on: April 26, 2006, 11:17:00 am »
Throw them in the back of the truck!!!
SgtDel
