Author Topic: aprox. HP  (Read 10853 times)
Offline 75 C20
aprox. HP
« on: April 24, 2006, 09:16:00 pm »
i have a 1975 C20 with a 350, granny manual trans. i have headers, new edelebrock 600 cfm carb., alum. gm preformence intake, straight pipes and glasspacks. Any Body got an Idea of aprxamately how many horsepower i got??
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
> aprox. HP
« Reply #1 on: April 24, 2006, 08:38:00 pm »
You didn't mention if your engine is stock for the vehicle...makes a difference.
If it is stock, It probably had about 180 horses.
SgtDel
Offline 1974Super10
Re: > aprox. HP
« Reply #2 on: April 24, 2006, 10:38:00 pm »
Around 230-250 horse, depending on the year of your motor... It would depend if the Cylinder Heads were 64cc or 72cc
Offline 75 C20
Re: > aprox. HP
« Reply #3 on: April 25, 2006, 07:38:00 am »
yeah it came stock with the truck
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: > aprox. HP
« Reply #4 on: April 25, 2006, 01:25:00 pm »
I am sure there wasn't over 200 hp in those years.  About 180 hp.
SgtDel
Offline Z28 c10
Re: Re: > aprox. HP
« Reply #5 on: April 25, 2006, 07:34:00 pm »
Get the engine code off the pad behind your alternater on the block and cross referance the last three letters,suffix code, on this link--
www.nastyz28.com/spmenu.html
For instance, mine shows CNB as suffix code, so I click
CMK- CUD, follow the codes down to find CNB and, viola, I've got a 1970 Z28 350 with advertised 360 factory hp. Now you have to take into account that that's flywheel hp. The drivetrain takes up a bit of power, but, it gives you a really good idea at what your dealing with.
 JayTater
 Z28 C10
Offline 75 C20
hp
« Reply #6 on: April 26, 2006, 08:07:00 am »
i'll do that, thanks
Offline roundedline
Re: hp
« Reply #7 on: April 26, 2006, 05:37:00 pm »
Keep in mind the Suffix code only is valid IF the internals that were in it when it left the factory are still there.  Just becuase it has X suffix on it doesn't mean you have a 360hp block, it just means you have a small block chevy.  The code along with the VIN ties it to a specific car/engine.
The 1975 C20's had 160 hp stock.  You may have gained 15hp.  But the engine is 31 years old and it probably doesn't have 175hp anymore...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 4/26/06 4:38 pm
Offline DnStClr
Re: hp
« Reply #8 on: April 26, 2006, 08:47:00 pm »
Roundedline, the 160 hp- is that off the engine or the rear wheels?
Don
87 Chevy Silverado
Offline roundedline
Re: hp
« Reply #9 on: April 26, 2006, 10:50:00 pm »
