Author Topic: gas gauge wiring help  (Read 6135 times)
Offline Leadfoot
« on: May 02, 2006, 02:01:00 pm »
I need some wiring help.. my `82 truck came with the dual tanks..I have done away with both tanks and the switching valve and installed a suburban tank in the back between the frame rails.. the new tank only has the ground and the pink wire from the sending unit,anybody got an idea where I need to hook this in to the original wiring to get a functional gas gauge??
Thanks,
Edited by: Leadfoot at: 5/2/06 1:02 pm
Offline roundedline
Re: gas gauge wiring help
« Reply #1 on: May 02, 2006, 02:40:00 pm »
The switching valve should have had a sending wire to it and each tank should have had a ground running to the frame rail.  If you know where the wire is for the sending unit, then you can just hook it back up.  As for the ground, just ground it to the frame.  I was thinking the sending wire was brown...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 123 pugsy
« Reply #2 on: May 03, 2006, 09:10:00 am »
Don't know about dual tank trucks,but mine comes down thru with the wire for the starter motor.
Pugsy
76 C10 LWB
TPI 350
Offline Leadfoot
WIRING
« Reply #3 on: May 03, 2006, 10:52:00 am »
Thanks for the help..I'll see what I can find..
