Author Topic: marker/tail light trim  (Read 7911 times)
Offline bfofish
« on: May 08, 2006, 06:21:00 pm »
anyone know if the trim for the the tail lights was ever painted from the factory?also the 81&up front marker?i have stainless/chrome ,but i want them black.i have tried painting them in the past ,but it allways wears off quickly.    has anyone found a good way to paint the stainless so they don't chip or wear off to soon?????
Offline 123 pugsy
Re: marker/tail light trim
« Reply #1 on: May 08, 2006, 08:05:00 pm »
Did you scuff them good with sandpaper? Also ,did you apply a coat of primer first? The trim on the back lights I believe are aluminum.There is a special primer for that.
Still not sure if the paint will stick to the front s/s trims and I work with s/s everday.Go figure.:o
Pugsy
76 C10 LWB
TPI 350
Offline bfofish
« Reply #2 on: May 08, 2006, 08:17:00 pm »
yea i've used just about everything i could think of with little results.
Offline toplessblazer
« Reply #3 on: May 08, 2006, 10:30:00 pm »
I don't think there is any good way to paint stainless steel. That's why all DeLoreans were silver, can't get paint to stick.
You could try powder coating.
Offline bfofish
« Reply #4 on: May 08, 2006, 10:35:00 pm »
i thought of that,just looking to save a few $$,but it might be worth the cost.
« Reply #5 on: May 09, 2006, 06:21:00 am »
Best way I found to paint stainless is grind it with 24 grit, prime it with self etching priner, prime it with high build urethane primers to fill the grind marks, sand that with 320, & paint it.
Offline gbskunk2006
« Reply #6 on: May 10, 2006, 07:04:00 am »
I was thinking of doing the same thing but just ended up buying new ones that weren't that expensive.  Most restore companies will carry them like Classic Truck Parts (formerly Chevy Duty) carry them so shop around.
Cheers
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Offline Bucks87silver
« Reply #7 on: May 18, 2006, 12:08:00 pm »
You might check this out. I've never tried it on stainless but duplicolor is reputable and a can isn't expensive. www.duplicolor.com/produc...lcast.html
