Author Topic: Warning lights help  (Read 6858 times)
Offline Zable82
Warning lights help
« on: May 19, 2006, 04:36:00 pm »
Noobie here, I think they are also named the idiot lights.  Would somebody happen to know how many/which ones my truck should have + plus how to fix them if they are not working?  The only ones working are the "choke" and "seat belts" one, I remember the "brake" used to work, I think now it's gone.  I'ts a Chevrolet 1986 c10 Silverado, thanks in advance.
Offline gbskunk2006
Warning lights help
« Reply #1 on: May 19, 2006, 06:27:00 pm »
Silly question, but have you tried replacing the light bulbs?
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Offline Zable82
Re: Warning lights help
« Reply #2 on: May 19, 2006, 06:36:00 pm »
I know, kind of silly, i'de imagine i'de be that way.  The thing is I'm trying to do an alternator conversion from SI to CS, and I need to know if my truck has a battery/alternator warning light?  I went to check my buddies truck, and it doesn't light on his either, do you know if my truck is supposed to have one?  I don't want to dissasemble the instrument panel in vain.
Offline cooltoolguy
« Reply #3 on: May 19, 2006, 08:27:00 pm »
does your truck have a voltage meter? if so you can buy a kit to wire the cs alt. with a resistor to make it work, if you alreadly have an indicator light you should be fine. if youu do have the gauge usually you dont have a light.
check this site out, www.madelectrical.com
Offline Zable82
« Reply #4 on: May 20, 2006, 11:15:00 am »
I don't have the light, so I'll go ahead and buy the kit with a resistor.  Thanks cooltoolguy, that solved my problem!
