Author Topic: 78 silverado  (Read 5711 times)
Offline 1funnyfarm
78 silverado
« on: June 05, 2006, 10:46:00 pm »
Hi just wondering if there is anyone out there that could tell me what the towing capacity is for a 78 silverado, two wheel drive?
thanks!
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
> 78 silverado
« Reply #1 on: June 06, 2006, 07:46:00 pm »
The answer greatly depends on the options.  Rear end ratio, engine, etc...
SgtDel
Re: 78 silverado
« Reply #2 on: June 06, 2006, 08:32:00 pm »
1/2, 3/4, or 1 ton?
Offline DnStClr
Re: 78 silverado
« Reply #3 on: June 06, 2006, 11:33:00 pm »
And also if you're talking about towing as a pull-behind or as a fifth wheel. A truck is rated for much higher towing ratings when used for fifth wheel towing.
Don
87 Chevy Silverado
Offline Ziptar
Re: 78 silverado
« Reply #4 on: June 10, 2006, 07:12:00 am »
I have a 79 Silverado 1/2 Ton with an Olds 5.7L Diesel. According to the owners manual it is limited to 2000 lbs towing capacity, so as you can see towing capacity varies widely based on the engine, trans, and suspension.
1979 Silverado C10 w/ Olds 5.7 Diesel
85 C10 Custom Deluxe
