Author Topic: gauges  (Read 7027 times)
gpday06
  • Guest
gauges
« on: July 02, 2006, 06:54:00 pm »
where can i get white face gauges that i wont have to do any work to change anything just put them right in i need the speedo, fuel, volt, oil press, clock, and temp all electric except for the speedo, ive tried autometer with no luck any help will be greatly appreciated thanks! '79 C10
Offline shaved80
Re: gauges
« Reply #1 on: July 02, 2006, 08:50:00 pm »
if you don't want to do any work to make them fit, you're only option is white faced stickers
search.ebay.com/search/se...category0=
gpday06
  • Guest
Re: gauges
« Reply #2 on: July 02, 2006, 11:38:00 pm »
nevermind i found the work thats been done online, ill do that
gpday06
  • Guest
Re: gauges
« Reply #3 on: July 02, 2006, 11:42:00 pm »
another question, i have the 5" fuel gauge but want to make it a small gauge like the volts, oil press, and temp, and would like the 5" tach, how would i go about changing that? do i have to buy another printed circuit and if so how do i run the wiring for the tach to the wiring harness for the printed circuit?
Offline yellow76
    • Truck photos- need some new ones!
Re: gauges
« Reply #4 on: July 04, 2006, 12:16:00 am »
covansclassic.com/parts/items.php?CA=21&UID=2006070401121668.113.47.73
These have got to be the sweetest set up I have seen yet.
I am saving my pennies- Just 5000 to go.
76 stepside 2wd
GMPP 350/350
basicly a big money pit, but a lot of fun.
Truck photos-- need some new ones
http://picturetrail.com/sfx/album/view/17304649
Offline roundedline
Re: gauges
« Reply #5 on: July 05, 2006, 11:38:00 am »
You need a tach cluster to do the least amount of work if you want a tach.  You will still have to repin the plug that goes into the cluster.  There is no unplug/plug in cluster that has different instruments/lights unless you use one identical to what you have from '78 -up.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
