Author Topic: Frame brackets question  (Read 5222 times)
Offline 80stepsideguy
« on: June 30, 2006, 12:03:00 pm »
Hello all,
i got here 4 frame brackets that help support under the front of the cab.2 are for 81-87  and 2 are for 73-80.The 2 front ones on my 80 are done but i am changing my truck`s cab to a 85 cab.My question is what mounts will work for this 85 cab,will the 73-80 mounts work fine or should i change them to the 81-87 mounts?Either way the 2 front mounts are comming off the frame,so what should i do?
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline 123 pugsy
Re: Frame brackets question
« Reply #1 on: June 30, 2006, 12:09:00 pm »
If you use the 73-80 ,you can use the same mounts.The cabs should be the same.
Pugsy
76 C10 LWB
TPI 350
Offline roundedline
« Reply #2 on: July 05, 2006, 11:45:00 am »
Whatever year the mounts came off of, you have to use the same year bushings..
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
