Author Topic: fuel pump/ relay problem and where is it?  (Read 5233 times)
Offline Dshlawren
« on: July 24, 2006, 09:49:00 pm »
i have a 87' c-10 i changed out my fuel pump, it worked fine then shortly after it quit. i believe i am not getting power to the fuel pump . i've tested the wiring to the sending unit and nothing no power i changed the fuse, i assume the fuel pump relay may have been damaged, in any event i am not sure where it is located. i am tempted to run a hot wire directly to the fuel pump sending unit- but afraid of blowing myself up! Could someone help , can't afford to miss no more days of work.
Edited by: Dshlawren at: 7/24/06 8:50 pm
Offline DnStClr
Re: fuel pump/ relay problem and where is it?
« Reply #1 on: July 24, 2006, 11:52:00 pm »
It may not be the relay. It may be a faulty oil pressure switch. GM designed the fuel system to automatically shut off if the oil pressure is lost. So the power to the fuel pump is tied into the oil pressure switch.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
Offline roundedline
« Reply #2 on: July 25, 2006, 04:55:00 pm »
When you switch the key initially, does the pump start up and prime.  the truck has to be running for the pump to continue to run.  If you just switch the power it will start and build pressure then stop.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
