Author Topic: IGNITION SWITCH REMOVEL WITH OUT THE KEY  (Read 7615 times)
Offline 87GMC1
« on: July 16, 2006, 10:31:00 pm »
HOW CAN YOU REMOVE THE IGNITON SWITCH IN A 1979 CHEVY WITH OUT THE KEY
Re: IGNITION SWITCH REMOVEL WITH OUT THE KEY
« Reply #1 on: July 16, 2006, 10:36:00 pm »
Pull the stearing wheel and lift out the hazard switch. There is a small bolt on the right side under the switch, it retains the cylinder. Remove it and the cylinder slides right out with or without the key.
Offline 87GMC1
« Reply #2 on: July 17, 2006, 12:40:00 pm »
THANKS I TRY THAT.
Offline 87GMC1
« Reply #3 on: August 13, 2006, 07:32:00 pm »
IT WORKED FINE NOW I HAVE A KEY TO START THE TRUCK. NOW THAT IT IS AT MY HOUSE I CAN START WORKING ON IT. THANKS KEVIN
Offline WickedC20
« Reply #4 on: August 14, 2006, 06:36:00 am »
thats what I need, my truck back at my house so I can continue to work on it. This is my mess I have to sort threw, the truck is about 45mins from home...it's such a pain to drive out there, even worse when I forget to bring a tool, or have the wrong part.
Inside the trailer is 70% of the parts I stripped off another C20,
