Author Topic: 86 silverado...want 4 light grill  (Read 10114 times)
Offline pcmcobra
« on: August 05, 2006, 02:39:00 pm »
I want to get a 4 light grill, like from an 88-91(?) f/s blazer/burb...to replace the stock grill.
Anyone sell a bolt on kit for this. What year/grill will fit without any or little mods?
thx
Offline lotopp79
Re: 86 silverado...want 4 light grill
« Reply #1 on: August 05, 2006, 06:38:00 pm »
I think this should be in the forsale wanted area bout I have the whole set up to bolt in that i am thinking about seling but there a direct bolt in in those year you can bolt the up to any 81 u-87 half ton cab or 81- 90 3/4 and 1 ton cab
Offline toplessblazer
« Reply #2 on: August 05, 2006, 11:58:00 pm »
coloradok5.com/grilleswap.shtml
Where are you located? I have a gm 89-91 core support and a used chevy grill in Mesa AZ. You would need headlight buckets and parking lights
Offline pcmcobra
« Reply #3 on: August 06, 2006, 12:58:00 am »
I'm in Pensacola, Florida
Offline pcmcobra
« Reply #4 on: August 09, 2006, 04:32:00 pm »
bump for some grill love
Offline roundedline
« Reply #5 on: August 09, 2006, 05:03:00 pm »
Are you looking to buy or looking for information on where to buy?
If you are looking to buy, this needs to go to the Parts Post.  If you are looking on where, www.usautoparts.com/  has kits, or did at one time.  They were actually frontends from salvage pickups, what they are now, I don't know...
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline pcmcobra
« Reply #6 on: August 10, 2006, 11:05:00 am »
sorry for any confusion. I want to find out exactly what I need before I start buying parts.
Thx for the info.
« Reply #7 on: August 10, 2006, 08:30:00 pm »
Offline pcmcobra
« Reply #8 on: August 11, 2006, 09:24:00 pm »
thx
Offline roundedline
« Reply #9 on: August 12, 2006, 10:57:00 am »
You need (from Neil's write-up) posted above...
Parts List:
‘89-’91 Radiator support GM part #15641713 *
‘89-’91 Grille (center portion) GM part #15628796 *
‘89-’91 Right headlight/turn signal bezel GM part #15628670 *
‘89-’91 Left headlight/turn signal bezel GM part #15628669 *
4 - ‘89-’91 Headlights, headlight buckets and trim rings GM part #16503172 (RH low beam), 16503171 (RH high beam), 16503162 (LH low beam), 16503161 (LH high beam)
‘89-’91 Right Turn signal lens GM part #5975228 *
‘89-’91 Left Turn signal lens GM part #5975227 *
4 - ‘89-’91 Headlight “pigtails” *
8 - ‘89-’91 Headlight adjusters *
4 - ‘89-’91 Headlight springs *
You can get a grille from any of the above trucks, BUT you HAVE to have the 89-91 core support from the Burb/Blazer also or it won't work.
Project Su
Jimmy 2WD Project
Offline pcmcobra
« Reply #10 on: August 16, 2006, 02:46:00 pm »
roundedline
u rock my friend...
Maybe after I get this stereo installed, I'll start on the grillage....
thx again
