Author Topic: Fuse block...  (Read 4070 times)
Offline autonuerotic
Fuse block...
« on: September 28, 2006, 01:41:00 am »
Has anyone figured out a way to clean up the terminals for the glass cylinder type fuses?  I was under the dash today and noticed they could use a little TLC.  I could do the obvious and re-wire with Painless, but there is no reason everything works as it should.  I just concerned with the fuses not making good contact.
Thanks,
-Auto
Offline 123 pugsy
Re: Fuse block...
« Reply #1 on: September 28, 2006, 06:06:00 am »
It may look dirty,but are you having any problems? If not ,don't worry about it.
Pugsy
76 C10 LWB
TPI 350
Re: Fuse block...
« Reply #2 on: September 28, 2006, 06:51:00 am »
Wurth products has a good spray electrical conection cleaner. I am sure there are others out there too. I have used a few others but they don't seem to work as good.
Offline RSBAD454
Re: Fuse block...
« Reply #3 on: September 28, 2006, 07:59:00 am »
you can use some emory cloth to get the surface rust off.
Toys are my game
http://
