Author Topic: master cylinder replacement  (Read 4324 times)
Offline jroth100
« on: October 12, 2006, 02:30:00 pm »
I have 77 k10 with stock power brakes and need to replace the master cylinder. Is there a difference between master cylinders used for 3/4 and 1 ton compared to 1/2. Is one better to use then another. thanks
Offline 1976Scottsdale
Re: master cylinder replacement
« Reply #1 on: October 14, 2006, 09:04:00 am »
I know that the visual design is different on the two.  The 1/2 tons use a single cover retaining rod, the 3/4/1 tons use a dual retaining rod setup.  not sure on the rest.
