Author Topic: Changing beds/ gas tank  (Read 5418 times)
Offline bicent truck
« on: October 15, 2006, 04:31:00 pm »
I have an oppurtunity to get a nice bed to replace my rusted one on my 76 fleetside, which has a round gas hole on the R/H side. The replacement has square door on the L/H side. Can the gas tank get switched to driver side without any issues, or can a hose run under bed from sguare door to the tank without problems such as the exhaust.Thanks guys, Rich
Offline Foxracing500r
Re: Changing beds/ gas tank
« Reply #1 on: October 15, 2006, 06:32:00 pm »
You should be able to switch your tank to the other side with no problem.
They make them Universal for Sides, There is nor LH RH when you buy tanks for that.
Hope that helps
« Reply #2 on: October 16, 2006, 10:39:00 am »
You will need to swap the tank brackets front to back.
Offline roundedline
« Reply #3 on: October 16, 2006, 03:43:00 pm »
I would also check the filler neck size vs what you have, and run a hard line across the frame for the supply/return lines.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #4 on: October 17, 2006, 09:00:00 am »
Thanks
