Author Topic: Instrument cluster swap wiring  (Read 5911 times)
Offline msjxx
« on: October 24, 2006, 08:57:00 pm »
I need help on the wiring of an istrument cluster. I have a 74 model Chevy 4 wheel drive. I have aquired a gauge cluster out of an early 80's model 2 ton truck. The new cluster has a tach and small fuel guage.
The printed circuit on the two clusters is wired differently, so i have to rewire for the new cluster. Does anyone have a diagram or instructions?
I purchased a chiltion's online guide, but it is virtually useless. I also purchased a guide from eautorepaironline.net but they did not have my model, so i had to get the guide for an 83 model which apparently does not have the same color wires.
Please help.
Offline roundedline
Re: Instrument cluster swap wiring
« Reply #1 on: October 24, 2006, 10:20:00 pm »
Without a complete and total rewire, you won't get that 80's cluster to work in a 74 pickup.  Don't try to hook anything up just for a test either, you will run the risk of frying it.
Look here for info:
73-87.com/7387garage/inte...meters.htm
BTW, I use Haynes manuals for most of the ones I convert.
If you want a factory service manual, look at www.helminc.com
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Edited by: roundedline at: 10/24/06 9:21 pm
Offline 1976Scottsdale
« Reply #2 on: October 24, 2006, 10:03:00 pm »
Come on, its not any fun until you hit the left turn signal and all of the lights in/on the truck begin to blink and the fuel gauge bumps up and down.:rollin
Offline msjxx
i plan to rewire
« Reply #3 on: October 25, 2006, 11:08:00 am »
I understand that it needs to be rewired, but i need a diagram, otherwise i have to figure out what each wire goes to. Can anyone help with a wiring diagram on for the 74 model?
