Author Topic: 73' and 80' grills interchangeable??  (Read 5775 times)
Offline brimc
« on: January 29, 2007, 12:24:00 pm »
Can a 73' and  80' grill be interchanged without any fitment problems?  Thanks
_______
Brian
Offline roundedline
Re: 73' and 80' grills interchangeable??
« Reply #1 on: January 29, 2007, 01:39:00 pm »
Not without swapping all the grille components (supports, latch support...) from the 73 to the '80 model.
You cannot simply remove a '73 grille and put it in an '80.  the latch on the '73-74 is centered, the 75-80 is offset.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 80stepsideguy
« Reply #2 on: January 29, 2007, 02:12:00 pm »
are you trying to put in a 73 grille in a 80 or a 80 grille in a 73?
thanks
pat
p.s. the reson i ask is because i got the necessary pieces for a 80 setup minus the grille(hood latch, grille brackets,center grille brace(piece behind the grille) ).All from a 77 truck but if you are trying to put a 73 grille in a 80 then disregard this.
1998 Chevy 1500 S/B 2wd
Offline brimc
« Reply #3 on: January 29, 2007, 11:36:00 pm »
Thanks for the info guys.  Will be doing a complete interchange between a 73' and 80', so  I'll have all the supports/latch/parts needed for a complete exchange.  Keeping an 1980 truck, and selling a beater  73' 3/4T ...but  I favor the appearance of the earlier grill, ....thus the planned switch.
____________
Brian
Edited by: brimc at: 1/29/07 11:41 pm
