Author Topic: Horn trouble  (Read 5169 times)
Offline maxwell75c10
Horn trouble
« on: May 26, 2006, 12:01:00 pm »
I have a 1975 c10 350, and my horn dosen't work.:|
I put in a new relay, pluged the horn in, and checked all the fuses. any advice?  or could some one tell me where a wireing diagram is. thanks
t
Show results
Offline 75 C20
Re: Horn trouble
« Reply #1 on: May 26, 2006, 07:08:00 pm »
Every once in awhile on my 75 c20 the horn doesnt work but its a lose conection right where the wires go into the horn. I ussally can just pop the hood and push the wires towards the horn and it's good to go for a while. If that doesnt work hook and electric meter or smth t o see where u lose power at- see if u do have power at the plug by the horn or if u lose it at the fuse box.
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
> Re: Horn trouble
« Reply #2 on: May 30, 2006, 06:47:00 pm »
You can run a jumper lead straight from the pos. terminal on battery to the horn and see if you hear anything....put your ear right up against the horn when you do this
SgtDel
Offline 777884chevy
horn trouble
« Reply #3 on: June 08, 2006, 04:00:00 pm »
I'll bet the horn is just shot. They may look pretty good on the outside but messed up inside. I have taken some off before that looked good but turned it upside down and rust came out     :rollin
