Author Topic: Headlight instrument panel lights  (Read 4687 times)
Offline Zip7SC
« on: March 19, 2007, 01:57:00 pm »
Hey everyone,
'86 GMC Sierra.  Dash instrument panel lights will go out on occasion (hitting bumps in the road).  I believe the problem is in the headlight knob or headlight switch.  I've purchased both from  .   Is this install a no brainer or are there some tips or tricks that could be of help?   I've searched all posts and a minor problem like this has never been discussed.  Appreciate any and all suggestions / assistance.  Thanks.
Zip
Offline roundedline
Re: Headlight instrument panel lights
« Reply #1 on: March 19, 2007, 02:35:00 pm »
If you are replacing the headlight switch it is a simple task.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: March 19, 2007, 07:13:00 pm »
You'll have to reach under the dash and grip the side of the switch with your hand.  You'll notice a little push-button on the side of the switch.  If you press that button in, it will release the switch knob...it will pull out.   AFter that, just remove the rest of the switch--which is straight forward.
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
