Author Topic: 305 swap to 366 hi deck engine in '86 C10 question  (Read 8243 times)
Offline Greasy Fingers
« on: January 24, 2007, 09:47:00 pm »
Has anyone any info on an engine swap in an '86 C10 or C20 to a 366 hi deck chevy truck engine.  I have a 350C turbo trans and 2:93 gears and I think that the 366 with the huge torque would be a great swap with decent mileage with a reasonable cost since there are millions of these with realitively low mileage in retires school busses.  Anyone with experience, etc.  Thanks Greasy Fingers!
Offline roundedline
Re: 305 swap to 366 hi deck engine in '86 C10 question
« Reply #1 on: January 25, 2007, 05:03:00 pm »
shouldn't be much different that a passenger BBC swap.  Just drop it in.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 1976Scottsdale
« Reply #2 on: January 25, 2007, 10:09:00 pm »
So much for revving ability... LOL.  366 will pull your house down... it just plans on doing it at 2000 rpm's.
« Reply #3 on: January 28, 2007, 09:04:00 pm »
Pulling the house at 2000 rpm's will work great. My old '86 has 2:73 rear gears so 2000 rpm would be about right I would think at highway speed?  What would you think?  P.S. it has a 350c Turbo Hydramatic with the lockup torque converter so there would be a 1 to1 through the Trans.  Would anyone hazard a guess as to the mileage on this setup??  Interesting project it would seem to me. - Greasy Fingers.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #4 on: January 28, 2007, 10:06:00 pm »
Just throwing this out there..,.,will a th350 or th350c work with a big block 366?
SgtDel
aka "Andy"
www.delbridge.net
1979 Big 10 383 stroker
1991 Blu 'Burb 3/4 ton 4x4
« Reply #5 on: January 29, 2007, 07:00:00 am »
Should its the same block as the 454
Edited by: Blazin at: 1/29/07 7:01 am
Offline Qship406
« Reply #6 on: April 01, 2007, 11:34:00 pm »
The 12" torque converter will not fit inside the TH350 bellhousing.  Everything else is the same as a normal BB to SBC conversion, make sure to get all the accessory brackets from the Tall Deck 366 Bus engine.
