Author Topic: turn signal indicator  (Read 4258 times)
Offline 75 C20
« on: April 02, 2007, 07:30:00 pm »
i just got the engine back in my 75 and fired it up last night- i had to replace a leaky water pump gasket and then fired it up again  tonight and when i was sittin in it i noticed my drivers side turn signal indicator is constantly on in my dash when my other lights are on -it does work if u flip the lever - it blinks,then when u flip it off it stay on-but i was just wondering y it would always be on- this is the 1st time its ever done that to me
edit* all the lights from the fron end r out and just layin there so idk if that makes a difference or not
Edited by: 75 C20 at: 4/2/07 6:39 pm
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Offline mike357
Re: turn signal indicator
« Reply #1 on: April 03, 2007, 03:09:00 pm »
mine did the same thing, i changed the bulbs and cleaned and scraped the sockets and it works good now.
Offline Blackstone
« Reply #2 on: April 03, 2007, 03:12:00 pm »
It's likely an indicator that a bulb is out. I think you'll be okay once you put the front lights together.
