73-87 Chevy & GMC Trucks
Readers Rides
Topic: Readers Rides (Read 5506 times)
bigblock73
Yeller
Readers Rides
March 01, 2006, 11:37:00 pm »
Mike (Swervin Ervin) had a bunch of readers rides on 73-87.com when he was running the show. Once he handed the reighns to me I removed it thinking it would take up too much space, be too much work, and what not.
Well, I have brought it back and have had quite a few submissions in the last two weeks. SO, if you want to see some cool 73-87's, check it out.
http://www.73-87.com/readers_rides/readers_rides.htm
Also, If you want to get your truck added, just follow the directions on the page and I will get it added as soon as I can. <p>...Jeff
'73 swb 2wd
Last Edit: April 12, 2007, 02:49:32 pm by Captkaos
Jeff
'73 swb 2wd
73-87.com
Blazin
Blazin new trails!
Re: Readers Rides
April 12, 2007, 01:32:46 pm »
Says page not found?
Re: Readers Rides
April 12, 2007, 02:48:59 pm »
Several links are probably not going to be working due to the conversion process. I will try an fix them, but if you run across one, it most likely will only give you a portion of the link.
Readers Rides
