Author Topic: Ls1 motor swap ! ! !  (Read 7015 times)
Offline mikeith
« on: April 11, 2007, 03:26:01 pm »
i have an ls1 from a 98 corvette and i want to drop it into my 86 c10, does anyone know what all i'm going to need? here are a few questions i have
where do i get the motormounts for the ls1?
what modifications do i have to make to make my heater and a/c?
will it bolt up to the th350 transmission that is already in the truck?
what other things need to be done for the swap to work?
Re: Ls1 motor swap ! ! !
« Reply #1 on: April 11, 2007, 04:34:26 pm »
I am putting a 6.0L LS motor from a 2500HD in our project truck located here.
you can see my progress and I listed where i got most of the stuff.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5225.0
The A/C pump won't work, you will need to get something else.
The power steering pump will need adapters to connect to the existing box.
I cannot say it will fit the TH350, so....
Offline mikeith
« Reply #2 on: April 11, 2007, 04:40:11 pm »
what mod has to be done for the powersteering pump?
why will the a/c not work?
« Reply #3 on: April 11, 2007, 04:57:23 pm »
The A/C won't fit in the framerail where it is mounted on the Corvette.  I really think you will need F-body Brackets.
http://hotrodlane.cc/77chevytruck/77chevy.htm
The steering box needs adapter fittings to connect to the pump on the motor.
the exhaust manifolds probably won't work either, you most likely need F-body ones also.
Offline mikeith
« Reply #4 on: April 12, 2007, 05:20:38 pm »
yea and come to find out they're only 2 hours away from me.... called em up and they're doin the swap!
« Last Edit: April 12, 2007, 05:28:07 pm by Captkaos »
« Reply #5 on: April 12, 2007, 05:28:46 pm »
Take some pics.  Post what you find out here.
